Rear brake levers, up or down ?.
Just want to check if the rear brake levers on a 1933 tourer should face up or down.
Mine face up, which might explain why the brakes come on when the car is loaded.
Easy fix provided I do not freeze to the garage floor while changing them !.
Martin.
Austin rear levers go down and back - nut should face rearwards.
Thanks Ruairidh.
Thought they were the wrong way round. Took pictures of them during
dismantling then I totally ignored them.
Did look on internet but did not find any 'good' pictures.
Nice job in forecast +3C temperatures. Really should get a heater for the garage.
Martin.
You may find the modern cap on your brake cable end fouls the axle tube, if so, fitting an original cap usually cures the problem.
Users browsing this thread: Scarlet O'Hara, 3 Guest(s)
