Car type: Special 1930 chassis
It is later.
The engine number should be on the top of the crankcase just in front of the oil pressure guage outlet.
Looks like a 3 bearing case to me... (but what do I know)
Hi
It has a high compression head from Mid 1936 onwards. It's rubber mounted so post 1930. Is there a bolt head on the side of the case on the manifold side ? If so it's 3 bearing. The engine number is the clincher, 1A 887 is just a foundry casting number.
The strengthening rib half-way down the side of the crankcase identifies it as a 3-bearing (post Jul 1936) engine.
Thanks chaps, I knew you would have the answers...
Now lets hope its not blocked haa haa
however seemed a good basis for some spares and wasnt silly money...
Don't separate the centre main housings from the crankcase, keep them together. They're match machined and while all looking the same shouldn't be juggled - centre main disasters usually quickly follow!!
