Yesterday, 08:54 AM
Yes - to be clear, the original pressed tin sump would not need removing to enable the engine to come out. The deep ali type that you can find nowadays that has a very clear 'square' front, do need removal. The deep ali type with the 'sloping' front might not need removal (mine, on the Cabriolet and the Box do not require it, for instance) Though Charles' problem suggests it might be an issue for some cars. But one that can be overcome...
