01-10-2024, 01:59 PM
01-10-2024, 02:42 PM
Those waterways are amongst the cleanest I’ve seen!
01-10-2024, 03:13 PM
01-10-2024, 08:24 PM
Managed to bore one out to 60 mm once and not porous ran great for about 150 miles then started letting in water,when dismantled the wall had split.It was about 1/2mm thick.
02-10-2024, 07:38 AM
Interesting, isn't it. I had a three bearing engine in the Cabriolet that I ran for many thousands of miles which was bored to +.080" and never gave any trouble. Pure chance or a different mould giving thicker cylinder walls?
02-10-2024, 11:51 PM
(02-10-2024, 07:38 AM)Hugh Barnes Wrote: Interesting, isn't it. I had a three bearing engine in the Cabriolet that I ran for many thousands of miles which was bored to +.080" and never gave any trouble. Pure chance or a different mould giving thicker cylinder walls? I would say pure chance - from what I hear for everyone claiming a successful 80 thou overbore there a number of blocks that give a problem. But go ahead and try - you could be lucky
04-10-2024, 08:44 PM
05-10-2024, 07:34 PM
Regarding the Ruby above with red wheels. Does anyone know whether having red wheels would be factory standard?
05-10-2024, 09:59 PM
Remembering Rubies when most were still in their factory finish they all had black wheels as far as I can recall. I would be interested to be proved wrong; memory is not so sharp as it used to be!
06-10-2024, 08:02 AM
Black was the standard factory finish on all models, but there were a few exceptions, as seen on the build records for the Ulster, for example:
![]() In the early days it was possible to order a car in a non-standard colour, and I suppose that order might include coloured wheels, but the option had been discontinued by the time of the Ruby, so it's unlikely that any left the factory with coloured wheels. This comment doesn't apply to coachbuilt cars, where, for example, most Swallows had coloured wheels. |
