01-10-2024, 01:59 PM
01-10-2024, 02:42 PM
Those waterways are amongst the cleanest I’ve seen!
01-10-2024, 03:13 PM
01-10-2024, 08:24 PM
Managed to bore one out to 60 mm once and not porous ran great for about 150 miles then started letting in water,when dismantled the wall had split.It was about 1/2mm thick.
02-10-2024, 07:38 AM
Interesting, isn't it. I had a three bearing engine in the Cabriolet that I ran for many thousands of miles which was bored to +.080" and never gave any trouble. Pure chance or a different mould giving thicker cylinder walls?
02-10-2024, 11:51 PM
(02-10-2024, 07:38 AM)Hugh Barnes Wrote: Interesting, isn't it. I had a three bearing engine in the Cabriolet that I ran for many thousands of miles which was bored to +.080" and never gave any trouble. Pure chance or a different mould giving thicker cylinder walls? I would say pure chance - from what I hear for everyone claiming a successful 80 thou overbore there a number of blocks that give a problem. But go ahead and try - you could be lucky |
