26-08-2024, 10:12 AM
(This post was last modified: 26-08-2024, 10:14 AM by David Stepney.)
My Seven was first registered in Fife. It's a standard saloon without the sunroof. I can't decide whether this was because of the Scottish weather or natural parsimony.
No Sunroof would have been handy this weekend !
Of the 20 or so miles i did drive in the rain, the window wiper only sprung into life within the last mile!
I did treat the window with a new bottle of Rain-x in the morning, but it didnt seem to work very well, the water did still hang on the window
You obviously weren't going fast enough!
I've thought many times about reinstating or fitting a sunroof on my RP, but to be honest the last thing you want down here when it's 30+ degrees outside is Mr Currant Bun bearing down on your bald napper. It's far better cruising with the windows down, the screen wide open and the air-con on full...
Reckless from slightly further south than Fife.
Hi Dave
Do you think the Trust might have more information on the rebuild? It would make a tremendous article for the Grey Mag.
26-08-2024, 09:27 PM
(This post was last modified: 26-08-2024, 09:30 PM by Tony Griffiths.)
As Howard says, it would be most interesting to discover more.
Engine and gearbox is coming out today as I have a noisy thrust bearing, which I’ve been putting up with for two years, a cylinder head stud that’s gone “soft” and a persistent gearbox crunch changing from third to top, so that sounds like a worn synchro….and the fun part is that the car is fitted with a Nippy sump, so that’s got to come off before I can get the engine out.
Rosie wants me to go shopping, which I try to get out of, but I’m beginning to think it might be a good idea and I’ll start tomorrow!
