Ulster/ Ulster Rep. Rear Brake Cable Routing
My own car, plus to the two others in the Worksop all have aluminium bonnets and sides.
Here is the situation on my own car, Robert.
It is fitted with semi Girling backplates just now, if I reverted to an Austin brake system I would have the same issue that Chris is anticipating.
FWIW I crawled underneath this afternoon and I reckon the issue could be solved by doing some fairly minor mischief to the body flange. I really need the axle in place so I can judge exactly where.
I do agree…
I have the same problem on my 2 year old CC body, just massaged the metal a little to make sufficient room ....
cheers
Matt
(08-07-2024, 08:34 AM)goodwoodweirdo Wrote: I have the same problem on my 2 year old CC body, just massaged the metal a little to make sufficient room ....
cheers
Matt
That's good to know Matt, as I really don't want to start re-working the body in any more major way.
