Can somebody identify this Lucas cut-out and fuse box. It's fitted to an RP but I don't believe it's original. Not like a CF or CFR2?
Thanks
Photo with covers removed.
Suffolk, UK
1925 Chummy
1934 Box
1925 Chummy
1934 Box
Lucas cut out
Can somebody identify this Lucas cut-out and fuse box. It's fitted to an RP but I don't believe it's original. Not like a CF or CFR2? Thanks Photo with covers removed.
Suffolk, UK
1925 Chummy 1934 Box
05-07-2024, 07:08 PM
is it not a CF3? from 32/33 time - see if you can see stamp on the edge somewhere...
05-07-2024, 08:12 PM
I am prepared to be corrected on the following, but I seem to recall that, certainly post-war, Lucas only supplied C3 cutouts as replacements for the earlier types.
05-07-2024, 08:53 PM
Not sure I've ever seen a C3. Post war Lucas had moved on from 3 brush dynamos with cut-outs to 2 brush dynamos with regulators, almost always RB106s.
I think JonE is right and it's a CF3. No markings on the front faces so I'll take it off the bulkhead to see what's on the back.
Suffolk, UK
05-07-2024, 09:33 PM
I put this up here and it might be handy... https://ulster7.wordpress.com/austin-electrics-h-hale/
05-07-2024, 09:46 PM
Thanks, Hale is always a great reference. Unfortunately the photos of the different cut-outs leave a bit to be desired. I live in hope of finding an original copy or even a better scan. If I ever find it I'll be sure to share it with the good people here.
Suffolk, UK
05-07-2024, 09:58 PM
Looks correct for PR for 1933/34.
06-07-2024, 08:21 AM
Hi
Looks like a CFR to me. CFR = Cutout, Fuse, Resistor so would suit a dynamo without an inbuilt summer charge resistor. The CFR presumably came before the CFR2. ![]() ![]() |
