Car type: Austin 7 Ruby 1938
Hi Bluebird, As it is a standard engine with the standard jets, I didn't think it right to mess with the jets. Maybe that's an avenue I should explore?
Fuel level in the bowl will directly affect the mixture when running. It needs to be at the correct level as specified for the carburettor. The level can adjusted by the thickness of washers under the valve.
Once the level is correct the jet size can be adjusted to give the right mixture.
Jets can wear. All those gallons of fuel running through them for all those years does enlarge them.
Car type: 1937 Austin 7 Nippy
Good morning Steve and Malcolm,
The Nippy engine did indeed come from the Thirsk area so I think you're correct in your assumptions. I'm extremely pleased to have come across it and managed to secure the unit and your comments regarding its quality are certainly encouraging and back up my own thoughts that it really was too good to miss - especially as there aren't that many in circulation anyway. I'm sure there will be a number of disappointed people who would also have loved to buy it.
There is also a very nice 65, complete with a "real" engine currently for sale at the same location and also, I believe, an MG TF. I'm sure the vendor wouldn't mind me passing on his contact details if anyone needs them?
Best wishes,
Nick
Thanks, Jim. I will consider jets if the exchanged float doesn't weaken the mixture sufficiently.
Regards, Graham.
Ooh stoppit! you're making me jealous as a sunny day without rain is a luxury we seem to have been deprived of by a rampant jet stream (according to the Met. Office)
That's all well and good but look at the traffic - it's like the M25. I tell you Margaret, I don't belieeeeve it!
If it makes you feel any better, it has rained today.
