I think Tony Betts sold a few... possibly Dave Dye made some too...
Yes, mine should be similar but obviously dimensions need to be exact. I suspect this is several inches too long.
Erich in Mukilteo
Erich,I’ve spoken with Chris about this.
05-05-2025, 07:35 PM
(This post was last modified: 06-05-2025, 03:23 AM by Erich.)
Tony, nothing is ever as easy as it ought to be. I've got everything, including the cable. However, the missing coupler is the issue. I had sent the dynamo back to the UK recently to have ti converted to 6 volt from 12 volt. I believe the coupler was there when I sent it. I believe the coupler, like the bushing, cannot be removed without removing the drive gear on the dynamo, which requires removing the end cap.
Erich in Mukilteo
Maybe you'll need a completely new cable with a connector already attached. Even then, some fiddling with the attachment point and the various dimensions at the distributor end will be required - it's always a puzzle when trying to get non-standard parts to work. The spade connector system looks to be a far more robust solution than a cable with its end ground square and fitting into a square socket.
