  • 1 Vote(s) - 1 Average
SU float
I am on the hunt for a replacement float for the SU that's on the Box saloon. If someone has one they would sell, I'd be very grateful. There's a small amount of liquid sloshing in the floatĀ and it has much soldering (round the back in the pic) on it by the p/o. I'd really rather find a good one than resolder it.
Not entirely sure what size the carb is but the inlet throat is 27mm so I guess it may be 1" 1/8th.
Float measures 35mm height, 39.5mm diameter, and the central hole is 6.9mm.
Edit - A bit of digging tells me it is a T1 type float.
.jpg   20250218_151447.jpg (Size: 126.42 KB / Downloads: 136)
Burlem sell ethanol proof floats.
