yes John I do still have the mk1 cabriolet its a great car to drive off road for this year it ran a big end and a replacement engine with a block rebore and new pistons started to smoke after only about 700 miles and got worseT and worseT after inspecting that engine I could see no obvious reason why, its original engine is now going back in and will be back on the road next year best Regards to all Rob.
Apologies for thread drift. A few years ago (before all that GDPR malarkey) I applied to DVLA for a copy of all they had on file for CLO293 / TSK490 and paid the £5. I was pleasantly surprised a few weeks later to get a wodge of photocopied microfilm records which covered owners going back to the mid 1970s. Someone must have spent a long time going through their records. This revealed that someone had kept the car for only a few months, long enough to pinch the original reg for their Porsche. An "A" suffix plate was allocated, which later on a dealer later changed to an "Age Related" plate which was a step in the right direction. All water under the bridge now !
Pedantry rules, OK? Or I that peasantry rool's ok? Okay?
Thanks John, at least you have been able to trace the history!
