25-06-2024, 01:27 PM
(This post was last modified: 26-06-2024, 12:29 PM by PeteUU.
Edit Reason: important info was omitted
Looking for a late A7 original carb jet key. Suitable for the side draught Zenith 26VA.
The 'T' shaped tool only has a cut out at one end, (About 10mm square), that fits the pair of 4 square headed bolts which secure the float chamber top to the carburetor. Contact me should you have one to sell. Thanks.
