And I thought the semi Girling compensating linkages on the brake cross shaft was over complicated
Bob
Bob
Balancing rear brakes on uncoupled cars
![]() Bob
24-03-2024, 12:47 PM
It is - the very-late rod rear brake set-up is much simpler.
24-03-2024, 01:27 PM
Simplest way to find out which brake is really working and which not? Invest in a laser temperature gun to aim at each drum after a run. About £15 on Amazon.
