Mystery parts, part 4
Is this getting annoying yet? I'm sorry if it is!
Wing stays, window winders, a Speedometer 1060 tpm but with the same reference as the Nippy one, a temperature gauge (sadly the ether has escaped into the ether) and some studs that look a bit like they might be front engine mounting studs?
Please let me know if you recognise anything (and/ or would like it)
The studs look like they are for the front fabric universal joint.
Box Saloon wing stays - these may be useful to Daisy for her Sports Van.
Possibly a Ruby window winder.
Fabric coupling fixing bolts, see here:  https://www.theaustinsevenworkshop.com/p...-bolt-9505
