Hi
The first one looks vaguely familiar, maybe in Bryan Purve's 'Source Book' ? The example you have posted is much better resolution.
I have never seen the second one before
Both of them look to be a labour of love !
it looks like plate 1017 on page 405 of the Source book
I had a copy of Tony's Ruby drawing 50 ish years ago, I believe it was a loose leaf insert from one of the handbooks, either Nicholson or Pitman's. Whether it came from there originally seems doubtful.
I find it very interesting to see the double lever system for engaging the starter shaft. Previously I was unaware of this mechanism inside the chain housing of marine engines. I first saw one in use on my late uncles boat on the Thames in 1953.
I knew that there was something familiar about that engine, a lot of our ships had them in the lifeboats.
