Champion D16 Spark Plugs
Advice required.
I am replacing the Spark Plugs in the 32 RP.
Are the Champion D16 plug OK or is there
another recommendation, and what is theĀ
recommended gap ? Undecided
D16s are fine. the gap should be 18 thou if you are running on the original 6 volt system. 25 thou if your car has been converted to 12 volt.
Thanks David. Regards.
Smiley.
