18-05-2021, 06:14 PM
I'm in need of a couple of three-bearing camshafts (the type with the two-piece solid centre bearing) for engines currently under rebuild. On one the shaft is so badly rust-pitted I wouldn't dare use it, and the other, for some reaon, has a mangled oil pump drive gear.
If you can help, let me know how much you would like with postage to Cornwall.
Thanks
Alastair
Thanks
Alastair
