11-08-2020, 07:59 PM
Hi John D
In reply to your observation elsewhere.
Decades ago with a lot of short runs my car was plagued with sludge but would not expect it to be a problem now unless there is a leak and/or using a quaint non detergent oil. Mayonaisse in the filler tube and valve cover is often a symptom of water leaks. SeeĀ
recent about thermostats. Can blank off radiatorĀ for short runs.
.Sludge is/was very damaging to roller bearings
