RP Dynamo/cut out
Nobody know what the inverted Y in a circle stamped onto some dynamos means?
Hi Dave
I have a DK4 distributor bought at Beaulieu many years ago.  It had no pinion fitted, and no pin hole drilled for one, so I  believe it was a new old stock Lucas "Service Replacement".  It carries the usual aluminium data plate, with silver characters on a black background.  On this plate is a silver Y (right way up) inside a silver circle about 3/16 inch in diameter.
So my guess is that the circled Y designates a service replacement, as distinct from something supplied direct to a vehicle manufacturer.
Unless anyone knows different ?
