Drilled water ways in block
I have tried to find out ,the diameter and depth to clean out waterways from block to head. Although I have seen it some time ago. Maybe some more learned can point at the right place.
(02-09-2019, 01:42 PM)Mogens Wrote: I have tried to find out ,the diameter and depth to clean out waterways from block to head. Although I have seen it some time ago. Maybe some more learned can point at the right place.
Try this one
https://www.pwa7c.co.uk/articles/articlescooling2.php
Charles
Charles .Thank you so much .Your response is just what I needed . I have been looking in all my clever books and all A7 club web side articles about cooling,but not this one . Very help full for me. Mogens
The hole between the exhaust ports should be 1/4"  and not 5/16".
