Hole in piston
#31
(04-10-2018, 08:25 AM)Ruairidh Dunford Wrote: What issues did you experience Tony?
Hi Ruairidh.
I didn't personally but Spares said they were incorrectly shaped - especially around the combustion chamber I believe.
Tony.
Thank you Tony.
I had a locally (NZ made) gasket and the holes in it were simply punched out not wrapped around edge like the better ones. I didn't use it (but can take photos if anyone really wants to see)!
Not sure about the shape, I'll see if I can remember to look. I have a better one as a spare to compare against.
Simon
