15-09-2022, 03:59 PM
Good afternoon. I have recently received many enquiries about the availabilty of headlamp reflectors.
Peter Jury of Classic Dynamo and Regulator Conversions is marketing a Projector Bulb which operates without the need for a reflector.
The cost of these per pair is less than the cost of having reflectors resilvered. This means that original reflectors can be used.
They are produced in BAd fitting (twin contact) and are dipping.
With a minor modification to the bulbholder these will fit any A7 lamp, including Lucas R510 Scuttle lamps. Aesthetically they look like ordinary bulbs when fitted.
I have ordered a pair and will report back on their effectiveness.
Regards from the creative county - Staffordshire
