08-08-2022, 02:20 PM
I'm sure I've seen this covered before but a search of the forum didn't turn it up for me, so apologies if it has.
I've recently managed to get a refurbished Zenith 26VA carb and I've realised the float bowl on the one I did have is different. In particular it is heavier and has a completely flat base. It also has "Z3" stamped on it.
I'm assuming this isn't correct for a 1933 A7? It has been on the car since I bought it a year ago and has been working, although the mixture has always been too rich. The attachment bolts are hexagonal rather than square, if that's a clue.
Thanks for any help and once again apologies if this is a rookie question!
