To the best of my knowledge, film companies hire, rather than buy the cars that they use, unless they're planning to damage or destroy it. I'm pretty certain that this Chummy would go the same way as the unfortunate RN in "Foyle's War" a few years go (blown up and burned).
No-one should consider selling their car to a film company unless they have a clear understanding of what it's required for.
I remember Clarkson describing in one episode of Top Gear that they had a selection of borrowed British Leyland cars. At the end of filming, there were taken away by the BL and returned the next day - but in different colours....
These are the points was making in my original comment. It is a very specific model they are asking for and the most expensive of standard models. So, my guess it isn't simply a piece of set dressing for perhaps the background of a 1940s garage, as any cheap 1930s tired car would work.
Could be they have a working chummy and plan to spray this one up as a look alike to be damaged/destroyed for some reason, or something else completely, perhaps a biop' where the subject was known to have a chummy so they need one to spray up and just sit there looking right.
It is all a little odd, hence my first suggestion needing more info before anything is offered, although I doubt they would confirm if it was going to be damaged or destroyed etc.
Could it be that when they say "Chummy" they mean any Austin Seven as is often the way when those who do not own an anorak describe most sevens ?
Clarification required perhaps
One way to get rid of a water-ski special....
