28-12-2021, 02:57 PM
I've just discovered this - any comments, or a user's experience?
https://smile.amazon.co.uk/Plasti-Dip-El...C72&sr=8-7
Brush-on electrical tape
28-12-2021, 03:17 PM
Love it! I use it quite regularly, especially for the harness on the car where I can't get a shrink wrap tube on it. Am also experimenting with discrete repairs to cracked interior vinyl panels.
28-12-2021, 03:28 PM
Seems a good enough idea. Does it come off easily?
28-12-2021, 05:05 PM
Hi
I used to specify this for those odd installations we did at work where it was difficult/impossible to use heatshrink. For example connectors and cables that you don't want to undo, or where the diameter varies over a wide range. Not especially prettty, but did the job.
29-12-2021, 03:16 AM
(This post was last modified: 29-12-2021, 03:16 AM by Tony Griffiths.)
Thank you for the comments. It does look to be very good ideal for those hard-to-reach and awkward jobs.
29-12-2021, 10:33 AM
(This post was last modified: 29-12-2021, 10:38 AM by John Mason.)
I have seen this on U tube when watching commercial Auto workshops (Garages to me and you) and it is widely used particularly if they have pierced the insulation on a wire for testing circuits. But I am not sure if ir is the same manufacturer.
John Mason
29-12-2021, 01:53 PM
Hi
Plastidip has been around a long time. It is used in the marine industry for sealing wire terminals in a damp humid enviroment. |
