01-09-2020, 04:47 PM
I can see the problem, the roof has been put on upside down!
SUNROOF DRAINAGE - RL, RM, RN
02-09-2020, 03:46 PM
Everyone's wisdom has been put to good use and the reconstruction of the RL roof is moving forwards again.
Many thanks!
02-09-2020, 04:44 PM
WOW !! That's quite a bit of work for the RN, over to you Martin (gulp)
02-09-2020, 04:58 PM
Jon,
The RN exit hole from the gutter is not at the front but underneath the front roof section as shown in Dave Mann’s photo. Cheers, Dave.
02-09-2020, 05:15 PM
Yes, it's the RL and RM that discharge through the timber. Austin no doubt found they had complaints with that system (surprise) so looked to 'improve' things with the RN.
02-09-2020, 05:48 PM
Blimey what speed are you doing to get the water to flow up the drain Dave? I've never experienced that and I can report our RN sunshine roofs are leak free. We are approaching the leaf fall season so checking of the drains for leaves is a regular service job, not mentioned in the makers manual.
02-09-2020, 06:42 PM
Must be the way I rebuilt the gutter holes Dave.I made them out of our kid's bike frame. If it's really bad weather I could plug the holes with a bit of plastic foam. The whole roof was completely disconnected from the windscreen pillars at one stage due to rot and on my daily commute to work in the 60's I had to hang on to the door on a certain bend to stop it flying open.
02-09-2020, 08:02 PM
Ah now I understand, if the drains leak it can cause serious corrosion of the peak and A posts, one of our RNs had lost most of it's peak and OS A post.
