Spade end plug leads
I finish these with heat shrink as well. As well as insulating, it makes the whole thing more robust and less prone to failing in the long term through vibration.
Ditto
.jpeg   50C746CD-2D61-4614-A9B4-A02B67F3A380.jpeg (Size: 126.74 KB / Downloads: 226)
Hmm, after seeing Howard's set up I can see I will have to remove some of the "patina" on my engine...
Don’t
Unless you want to swap it for mine  Smile Smile Smile.
It’s a new build so hopefully it will tone down soon.
Love the hoses - where do they come from?
Hi Bob
They are an eBay purchase listed as EPDM wire reinforced hose (32mm).  Sorry can’t seem to copy and paste the listing.  I made the clips myself from 12mm brass strip.
Hope that helps?
Brilliant! Ordered.
Thanks
