05-07-2020, 09:06 AM
(This post was last modified: 05-07-2020, 09:09 AM by Dave Wortley.)
Derek, I had problems with my chummy which I thought I had resolved with various heat shields and a red fibre insulator between carb and inlet manifold. It’s on here if you search “boiling petrol”. BUT Tony Griffiths now has the chummy and he had a different solution involving wrapping copper wire round the manifold/carb junction. Note the chummy has a sidedraught SU carb. Tony may be able to show you his modification on here. Cheers, Dave.
Sorry, problem with ipad! Or my incompetence!
