12-04-2020, 06:09 PM
Yesterday, I drove my A7 on full speed, when suddenly the engine went off. I checked the ignition and realized that the distributor finger did not turn when the engine turns over. I have a VW distributor - probably some Bosch 009 repro.
I dismantled the distributor - I'm not aware of how it should work but when I turn the axle, the plate with the weights does not turn, nor does the drive shaft where the finger is mounted.
Can anyone give me some advice where the issues is located ?
thanks
Oliver
thanks
Oliver
