Calling AC Chummies near Herefordshire!
We're hoping to find someone with an AC Chummy that we can take a look at as close to Herefordshire as possible. Specifically, we want to check the radius of the rear corners of the body to ensure our formers are correct. We already have some measurements and a curve we believe to be correct, but would like to confirm this before producing rear body hoops for the model.
Any suggestions would be appreciated!
My mate has one, the bodywork in fine fettle thanks to Mr Goodfellow up here in North Shropshire. No trim or anything inside as it is just a tub. If you get no joy let me know and I'll ask him. My brother in law is currently borrowing his traction engine
Cheers Hedd, that might well be a possibility.
There's a very original one here with me Dave.
Thanks, Mick.  I'll email you.
Martin I could send you a cardboard template of a '23 AB rear top edge, which I think from memory was the same as an AC.  Unfortunately I accidently discarded my '25 template to check. Cheers,  Bill in Oz
