05-02-2018, 10:44 AM
You are very welcome - good luck with project.
coupled brakes in 1926?
05-02-2018, 06:42 PM
05-02-2018, 09:18 PM
(This post was last modified: 05-02-2018, 09:20 PM by Mark Atkinson.)
(05-02-2018, 06:42 PM)Rob Hanauer Wrote: Is this the accessory coupling bit? Hello Rob, That’s interesting, I guess there are 3 vital questions; What is the internal diameter of the clamp? What is the Center to Center measurement, clamp to hole in the lever? If the first two questions check out, then would you like to sell it? Regards, Mark
05-02-2018, 10:06 PM
