I think that 8 degrees of distributor advance would give 16 at the crank. Your strobe seems to confirm this.
That plate looks in surprisingly good condition, so it's likely that your DK4 is working well. Unusual I think.
I got new springs from the distributor doctor. One was lighter than the other. The various old distributors I have seem to have both springs the same.
On another car we have a more modern, 1972, distributor (Not Austin). That has one weak spring and one strong. I think the reason for this is that at cranking speed there is no advance, but as soon as the engine fires the weak spring is fully extended, hence advancing the ignition. Thereafter the strong spring takes over. This automatically retards the ignition for starting.
We gave up with the DK4s, they were all very worn. Now have an Accuspark which works very well. Having all new mechanical advance mechanism is a big advantage.
I tried a Bosch, it was a disaster. I believe the Bosch look-alikes are to be avoided.
If the strobe shows a gradual advance then it must be working well. I suspect that worn ones don't advance properly.
I find the Bosch units too harsh, even with the stop modified.
I have some original spindles here that you are welcome to try, if you want.
I have a Bosch 009 on my RP which came from Willie McKenzie. It has been working perfectly for the last 15 years.
Thanks for the replies gentlemen, After stripping the gear and removing the spindle, I welded the worn areas and filed the holes back to 8.5 mm diameter. Now reassembled the engine is running smoothly but as there was some free play in the bob weights and the springs slightly stretched , I'll run it as is at present but will be looking at getting a 009 unit and possibly electronic operation to help smooth out any roughness in operation.
For distributors where the springs hang slack as many did as new there is a marked difference between hand cranked static advance and low speed advance as per a timing light. if the weights and pins not seriously worn, some idea of max advance on car can be obtained by locking at full advance with a washer and long screw down the middle, all twisted and locked at full advance and hand cranked. The hard part is finding a long correct thread.
