Mk 1 Ruby repair
I have removed the engine in my Mk1 Ruby to fix a cam shaft bolt oil leak. When removing the lower bolt on the starter motor,  the lower part of the casing fell away on the crank case. Judging by the condition of the surface it has been like that for sometime. Does anyone know who does this type of repair please? I can email pictures if required. Many thanks.
