SU Carb on a chummy manifold
#21
The inlet and carb faces were parallel.I used an 1 1/8" but don't know what it was originally fitted to.I did grind out the ports inside as much as possible before welding on the SU flange.
I remember the updraught manifold is quite a small bore especially the vertical bit.That's why I wouldn't go the 90 degree adapter way.
The box saloon was good for a genuine 60 on the flat,throttle tempered by the original 1 5/16" crank.
Just remembered I'd found an incomplete pair of early sprite/midget twin carbs which the adapter was cut from.
(06-11-2020, 08:57 AM)Austin in the Shed Wrote: The inlet and carb faces were parallel.I used an 1 1/8" but don't know what it was originally fitted to.I did grind out the ports inside as much as possible before welding on the SU flange.
Dave,
Maybe you should cast some up, I'm sure there would be a market for those that want a gravity fed SU.
Mark
