Can anyone tell me if 1933 Box 7 RP 's were ever fitted with Lucas 1130 pattern side lights ? .My 7 has these fitted , and I want to change them to the correct units . Which type should they be ?...….and where could I get a pair ?
Not from the factory. The sidelamps were pilot lights built into the headlamps.
A my car has a chassis number within 118 chassis after the changeover to the early Hardy Spicer joint on the 14th June 1933, I reckon my car was built between the 14th and 16th June that years, which means that it has just celebrated its 86th build birthday. Its registration birthday is 4th July.
