Thanks Howard. I have a Special with gravity fed fuel, so this might be ideal. All I have to do is see if it can fit under the extractors. I bought the car only recently -- it has an SU on it at the moment, above the manifolds so it doesn't have much head room when the tank is low on fuel. I'm not sure what type as yet. It has been decades since I messed around with SUs.
Geoffrey
(Edit: I have no idea how to insert an image from my computer, so you'll have to use your imagination.
Geoffrey
