Can someone tell me the thread size of the two set screws that hold down the top cover that fits on back end of engine, covering the flywheel/starter ring.
Mine have stripped and I need to helicoil, so need to be certain of thread size used.
On our 1929 engine it's 5/16 BSW
A good rule of thumb as that if it is soft metal such as alloy or cast then a course thread such as Whitworth is used.
John Mason.
Many thanjs for replies, most helpful. Regards
5/16 Whit on 1934 crankcase.
