21-06-2023, 08:13 PM
hi all, What is the easiest dimension to check on a bare chassis to determine if it is short or long wheelbase?
thanks
Colin
thanks
Colin
Chassis dimensions
thanks Colin
21-06-2023, 10:06 PM
The Archive holds engineering drawings for the various chassis, so a look there would be a good place to start. As an example...
https://archive.a7ca.org/collections/tec...em/TD0014/? hth...
23-06-2023, 12:40 PM
Quickest way is to count the holes behind the handbrake fixing. 9 is a long chassis:
lwb chassis2.jpg (Size: 100.96 KB / Downloads: 262) 7 is a short chassis. SWB chassis2.jpg (Size: 55.07 KB / Downloads: 261)
08-07-2023, 11:42 AM
Thanks both - that was a great help.
10-07-2023, 08:20 PM
Just noticed, very late chassis with rod brakes - and therefore a modified handbrake mounting bracket - has eight holes.
(The front one of the nine on the LWB chassis is missing.) |
