08-08-2022, 06:57 PM
(08-08-2022, 06:15 PM)Colin Wilks Wrote: I was talking to a chap with a racer at the centenary. One of his tips was to drill the underside of the axle near the hub so that oil which would otherwise spoil the brake linings dripped onto the road instead. Anybody else done this?
An old time dodge that treated the symptoms, not the disease, Colin. Far better to make sure that the oil doesn't leak out of the diff than trying to keep it off the brakes if it does. Not difficult to achieve.
