Oil holes in lay gear assembly
Thanks Chris I made a tool just like that and it worked like a dream. The bicycle shop had balls the right size so I put a new set in. The little tool for removing the bush from the layshaft worked well and I put a shim behind the bush and now have an end float of .004”.
Thank you for your comments Parazine and Bob.
Cheers.
