10-10-2019, 09:46 AM
(This post was last modified: 10-10-2019, 09:47 AM by Reckless Rat.)
Mine is anchored to the offside axle mount. Its been like that for at least 20 years with no obvious problems and the handling is much better. I didnt even cut the drop link but just pushed the unused end between the two damper blades. Quick, easy no cost fix.
Thanks chaps - very reassuring. I now have confidence that nothing is under too much strain.
Mine is anchored on the nearside, usiing the arm with two "seperate" discs.
Rick
In deepest Norfolk
