21-03-2020, 08:38 AM
Stuart Palmer is making those at the moment.
The Brookfields Special
22-03-2020, 09:55 AM
what about wrapping the exhaust for the fuel pipe?
Or wrapping the fuel pipe!
22-03-2020, 10:32 AM
HI,
I would put the Fuel pipe on the inside of the Exhaust closer to the intake manifold and put the expansion coils below the shut off tap. Other wise the project is looking Great. Colin NZ
22-03-2020, 11:04 AM
Hi Jon and Colin
Yes Jon I’ve considered wrapping the exhaust and or the fuel pipe. I’ve also tried routing the fuel line under the exhaust but it meant that access to the float chamber banjo was impossible. I’ll see how things go when the engine is running! Thanks for the kind words. Cheers Howard
22-03-2020, 12:23 PM
I'm sure it'll cool if it's close to the louvres and that big hole. The line looks OK for avoiding vapour lock too.
Watch out while stationary though...
22-03-2020, 02:15 PM
do you mean this Stuart Palmer?? https://rally200022.wixsite.com/austin-7...l/toy-shop
Because about September 2018 I've tried to get one from him but he was too busy with his other business and I have since not got word from him he had them in stock again
30-03-2020, 10:41 AM
Hi All
Just a quick post to say that she started up this morning! Second attempt (timing not quite right first time) Dynamo not charging, exhaust very noisy, rev counter may be reading 2x too high and the led indicator warning light comes on (ghosting electrics or interference?) So lots to do and I can’t go anywhere (Covid and the fact it’s not registered yet!) ![]() ![]() ![]() ![]() Cheers Howard PS Would have posted a video but it won’t load up ![]()
17-05-2020, 05:54 PM
Hi All
Not posted on this thread for a long while so I thought I’d show some bits and bobs I’ve done recently. To be honest I’m struggling with things to do until the lockdown is over. While the car has been started I can’t take it out even if I was to ignore the Welsh Assembly Lockdown rules as the car isn’t registered, I haven’t been able to have it inspected by the authorised club member and DVLA aren’t accepting applications! The dragon mascot and temperature gauge, Brookfields logo and manufacturers plate ![]() I’ve also decided to instal a dropped axle but again I’m waiting for lockdown to end before I can get the eyes repaired at chez Dunford. Cheers Howard
17-05-2020, 06:05 PM
It's all looking very good Howard, crack on!
