Coach lines for 1932 RN saloon.
And he had shaky hands did you say Mike, until he started the coach lines?
He had shakey hands even when he was doing the coachlines! the extremely long bristles on the brush absorbed the shake so the end result was fine.
May be of interest. I have a vast stock of " stick on" coachlines, as used to customise 1970's cars. All colours, thin/thick lines, doubles /trebles. I will put an "Ad" in sales and wants.
I believe the brush with extra long bristles is called a rigger. In one of the Austin works films there is a few seconds devoted to the sign writer applying the fine lines in which he completes most of the side of Seven.
