05-09-2018, 04:24 PM
Hi all,
Looking for the pinion retaining ring for a 1931 (long nose banjo) rear axle. Managed to find a torque tube for my axle build at Beaulieu thanks to Tom Hunt - now the search begins for the ring that secures the pinion bearings into the bottom of the torque tube. If you have one tucked away somewhere I would be most grateful.. Thanks very much..
