Silicone Base Gasket
#21
in my experience, any non fibrous gasket should be fitted dry. eg silicone or rubber type gaskets. They need to grip the surfaces which prevents the gasket distortion.
R and Duncan,
Yes I agree. Being thick today! (Too much sun).
My big tip to go along with the brake cleaner, which I use a lot, it to blow it off with an airline. Dries it instantly with no contamination.
