Lambswool in my own Chummy - lovely it is too.
I believe Barry Clarke produced (financed?) a run of the original weave many years back so I understand, does anyone know if it can still be purchased?
11-04-2018, 04:46 PM
(This post was last modified: 11-04-2018, 06:02 PM by Erich.)
Has anyone thought of or tried to use studs and nuts to hold the starter housing down? My thought is that using Loctite to set a stud would mean that the threads in the crankcase wouldn't be subject to repeated tightening and loosening.
Erich in Seattle
Car type: 1932 RN saloon
Erich,
On some A7s there isn’t enough room to get the housing high enough to pass over the studs.
After my welding repair I use studs. Works fine.
I also use studs for the sump for the same reason
Charles
