Now, there's an idea... - Printable Version
+--- Thread: Now, there's an idea... (/showthread.php?tid=9881)
Now, there's an idea... - Tony Griffiths - 04-03-2025
Now, there's an idea: instantly-adjustable friction screws on the Gas and Ignition levers. And the car, a supercharged Ulster - what do we know about that example?
https://auctions.hampsonauctions.com/auction/lot/lot-62---1931-austin-seven-ulster/?lot=2178&so=0&st=&sto=0&au=29&ef=&et=&ic=False&sd=0&pp=96&pn=1&g=1
RE: Now, there's an idea... - dickie65 - 04-03-2025
My car has adjustable screws from the factory in 1934 you just need to adjust them with a screwdriver evey so often.
