Fitting girling drums on a standard hub - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Fitting girling drums on a standard hub (/showthread.php?tid=9640) |
Fitting girling drums on a standard hub - leaf200 - 16-10-2024 Hi, I was looking at a girling brake drum in my workshop and wondering what it would take to fit on a standard brake setup. I always thought the issue was it fitting in the wheel but I tried a wheel centre and the only issue I could see was the spokes might foul the fin. It looks like the braking surface would be in the wrong place and a spacer may be required. Has anyone fitted girling brake drums on a standard setup Thanks RE: Fitting girling drums on a standard hub - Ruairidh Dunford - 16-10-2024 Do you mean, using them on Austin stub axles and shoes etc? RE: Fitting girling drums on a standard hub - leaf200 - 16-10-2024 Yes just fitting them to standard brakes RE: Fitting girling drums on a standard hub - Dave Mann - 17-10-2024 The Girling drums will not fit the earlier brakes, Tony Betts did supply cast iron drums which will. RE: Fitting girling drums on a standard hub - Austin in the Shed - 17-10-2024 I think just cleaning up the o/d in a lathe and they do fit,just need to check the stud faces meet. RE: Fitting girling drums on a standard hub - AustinWood - 17-10-2024 I think the offset of the linings to the hub face is different so they don't fit onto the hub. However they do fit the later vintage wheel. I had a 1930 saloon with Girling front axle and original 19" wheels. RE: Fitting girling drums on a standard hub - Dave Mann - 17-10-2024 They won't fit a 1932 RN with 1.25" brake shoes without reducing the diameter of the back plate. |
