Where to Buy Silver Solder - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Where to Buy Silver Solder (/showthread.php?tid=9570) |
Where to Buy Silver Solder - John P - 05-09-2024 Hi, I need to source a small amount of both Easy Flow and Easy Run (hope that's the correct terminology) together with some suitable flux. Probably one 200mm wire length of each grade will be enough or alternatively flat material I can cut down. I haven't done any silver soldering for probably 30 years so I guess I may end up wasting some re-learning but at current prices I need to minimize waste. Anyway, can anyone recommend a supplier or is it just a case of searching e-bay? John. RE: Where to Buy Silver Solder - Howard Wright - 05-09-2024 Hi John I’ve bought brass tubes and ba screws from this place. https://maccmodels.co.uk/ They list various silver solders and fluxes. Cheers Howard RE: Where to Buy Silver Solder - sheddweller - 06-09-2024 Hi , most model engineer suppliers have stocks of silver solder and flux. RE: Where to Buy Silver Solder - Jamie - 06-09-2024 I have just bought some silver solder from Cooksons Gold and from Kernocraft. I am using borax as a flux. Jamie. RE: Where to Buy Silver Solder - Lowespeed - 06-09-2024 I got mine from : Edwards Metals Ltd 37 Birch Road East Wyrley Rd Witton Birmingham B6 7DA tel : 0121 322 2366 Do an extensive range of Items, like rivets, bar, tube, sheet metals etc; were Educational suppliers to Birmingham when we did "proper" Metalwork ! RE: Where to Buy Silver Solder - Parazine - 06-09-2024 You can get it from your local BOC Gas & Gear depot or online at www.boconline.co.uk. Wherever you get it, be prepared to sit down when they give you the price - it is certainly not cheap! RE: Where to Buy Silver Solder - JohnD - 06-09-2024 Around 15 years ago i found several lenghs of silver solder on a golf course - very strange but i did my bit for the community and took it home so it would not effect anyones elses play! There is only around 6" left, so i need to order more - very helpful suggestions, thank you |
